Anyone have any spare parts for a 1:18 scale Bburago 1962 Ferrari 250 GT?
The used copy I have found is missing a couple of wire wheels/tires, both valve covers and the intake manifold with 12 carbs. Otherwise in pretty fair shape. I realize this is a real long shot. Thanks.
I might be able to help you..............
I'll check when I get home tonight
Thank you, Frank.
Well I have a mixed bag here.........
I've got wheels - and likely tires although I can't say for sure if they came from a Bburago 250 GTO, 250 LM or some other old model with plastic wire wheels. I do have the hubs as well.
I also have the valve covers but do not have the carbs.
That is a good start for sure.
I have the two original complete rear wheels and tires, and the spare. The spare is missing the knock-off hub. I failed to mention that the hood and trunk lid are missing, but I've been able to make replacements. The valve covers would really work out well as I believe the manifold and carbs could be fabricated fairly easily. If I seal the trunk lid, then only one complete wheel/tire/hub unit plus one knock-off hub would be needed.
send me a photo or two........
I'm away this weekend but once back I can send you what I've got.
If you can send me some photos of the wheel and tire you need I can match them up.
Send photos and address to fiacobra289@msn.com
Photos sent. If you would need others, please let me know, Frank. Thanks again!
