I have a question a...
[Closed] I have a question and need some help,
3 Users
(@dickjwa)
I have never used chrome foil or tape before. I have some chrome tape that looks good but I can't get it on the rear bumper of my Edsel wagon without wrinkles in it and I even used a heat gun to help and it did a little but not enough.
Is the foil better and can anyone tell me the best way to put it on ?
Thank's.
(@robert-lawhn)
Noble Member
I have used Q-tips to softly spread chrome foil but....
I still usually do a lousy job.
(@David Holcombe)
I work with 1:43 with pretty good results. Here are some hints:
I use the original Bare Metal Foil. The "new" stuff is too thick.
Don't keep the foil too long. It seems to get wrinkle-prone when it's old.
I have to order it from the Bare Metal site, but when I call they do not charge the extra dollars for a small order.
Here is a before-and-after example of the results:
photo no longer available
Good luck! David from Forum 43
(@dickjwa)
Thanks, very nice work. I hope I can get mine as good.
(@Doug Switz)
David, how do you not get the newer style foil, and at the same time keep it from getting too old?
(@David Holcombe)
The older foil is still available from Bare Metal.
