Lane Exact Detail O...
[Closed] Lane Exact Detail Olds Cutlass- help?
3 Users
(@Zack Cutler)
Hello all, I hope you're doing well. I have a quick question- I've got a '71 Lane Cutlass, and the driver's side front wheel, it looks like the (if it were a real car) upper A-arm has broken. The top of the tire leans in at about a 45 degree angle. Picking it up, it kind of hangs down.
Is this a common problem with these? Does anyone have any suggestions on how to fix it? Anybody got some spare Lane Olds parts they're interested in getting rid of? 😉
Thank you!
Zack, I think I can help if you provide a few pics of this "negative camber" issue. I believe...
...your upper control arm is broken and I think I can show you how to fix it if you can post a few pics.
BTW: I do NOT own this particular 1/18 Lane.
(@franklemire)
Chris and Zack.............
Lane built most of their cars with the same basic front suspension setup. It should indeed be pretty easy to fix.
As an aside - if it is a broken part that is now partially missing i might have a replacement part that could work.
(@Zack Cutler)
Thank you!
I will try and get pictures tonight. Since Christopher posted, I've been meaning to, but keep forgetting. Smile
Correct Frank. I have other Lanes and they too sufer from negative camber.
