Help with D4C Delahaye repair
I just opened the Delahaye for the first time and the right taillight, trunks strap and its handle were laying on the bottom of the box. Looks like a relatively easy repair but what is the best adhesive to use and how is the best way to hold the strap in place while adhesive sets up. I was thinking of using blue painters masking tape. Does anyone have a better idea?
I would use Loctite ultra gel control.
You only need a very small amount, and for small parts like you're talking about, it'll hold quickly. You shouldn't need tape. You'll probably be able to just hold it gently with the tip of an x-acto blade for about a minute, and then let it cure on its own.
I've made repairs to similar cars using these tools, and they work well.
Hope this helps!
I use the same things for small repairs with good results.
David Vandermeer
Corinth, Texas
My only concern is that there is a slight curve to the trunk and I don't want the strap to "spring" back. That is the reason for the painters tape.
Roger, you are exactly right, and in my opinion this is a delicate repair ...
... requiring lots of skill. I had exactly the same problem, some time ago (3 years) I asked the forum how to repair it and I did not receive a satisfactory answer. So I postponed the repair. Over the last years I acquired lot's of experience and can share my intended technique but I have not tested it yet. If you are willing to wait for a week or so, I can repair mine and post some pictures. I completely agree with Dan and David on the glue's choice, the problem is ... you have only one clean shot, if the super glue spills to the paint you will see the cyanoacrylate's ugly face.
I will await your post. I'm not in any hurry.
Roger, Chav's absolutely right about the glue. This requires a VERY small amount,
Like, just as much as you'd pick up on the head of a pin, spread onto the part to reattach. And good point about the curve of the rear deck. I didn't look closely at the model before.
Try a few dummy applications of glue on some waste material that you won't mind throwing away. The gel I recommended makes it very easy to control, but if you've never used it before, definitely run a couple of trial tests.
Best of luck with your repair! That is a splendid model!
Chav, I'm looking forward to your post, too.
I've gone to 5 minute epoxy for all my repairs. My hands shake when doing this fine work and if some of the epoxy gets on the car I can wipe it right off. I do have to figure out how to hold some parts in place till the epoxy sets but at least I haven't ruined any models as I have with super glue type products. For what it's worth......
Have you considered a glue stick to hold the strap in place? Any excess cleans up with water.
