Information need on FM 1912 Christie Front Drive Steamer (Fire Engine)
Could someone tell me if the hand crank for the engine is designed to turn? The instruction sheet says that it is, but the one on the one I purchased appears to be in a fixed position. Any help is appreciated! Thanks: :-/
Very interesting......
I have two of these little beauties and on one of them
the crank turns and the other one is as tight as can be.
It may be painted tight or it may be a change in the
design. I would not force it as the crank may break if you
do. It's possible that a little CRC or Liquid Wrench may
help.
BTW, if anyone has a wreck, I need one of the large
hoses and the plastic cradle that holds the model in the
styrofoam box.
My crank turns, a little stiffly though
get to the LOUNGE, quick!
