1/18 1966 Mercedes ...
1/18 1966 Mercedes Benz 200 Sedan Project
5 Users
16 Reactions
This 1/18 Norev 1966 MB 200 sedan ALWAYS bugged me because despite everything opening.... the sunroof was sealed.   Well, I had to unseal it.  The sunroof is NOW removable.  I also took care of a few other things (lowered the suspension, detailed the wheels, fabricated a trunk mat, etc.. )   Eventually I'll do a better spare wheel... but THAT'S an entirely different project for a another time.
PART 1 OF 2
MB 200 15
MB 200 1
MB 200 4
MB 200 5
MB 200 6
MB 200 7
MB 200 31
MB 200 32
MB 200 33
MB 200 26
MB 200 27
MB 200 28
MB 200 29
MB 200 30
MB 200 36
MB 200 37
MB 200 38
MB 200 39
MB 200 40
MB 200 41
MB 200 42
MB 200 48
MB 200 34
MB 200 35
Great job!  Patience is a virtue and you seem to have a lot of it.
PART 2 OF 2
MB 200 4
MB 200 6
MB 200 8
MB 200 9
MB 200 10
MB 200 12
MB 200 11
MB 200 13
MB 200 16
MB 200 17
MB 200 19
MB 200 18
MB 200 20
MB 200 21
MB 200 22
MB 200 23
MB 200 24
MB 200 25
MB 200 43
MB 200 46
MB 200 53
Roger Kerr, David Green, Tony Perrone and 1 people reacted
What a tremendous improvement! The final pics show off a fabulous model - WELL done Chris, WELL done!!
Marty Johnson
(@marty-johnson)
Your documented modification process clearly demonstrates how much work is required to do the engineering and execution of modification projects.  With diecast models that were never intended to be modified, the work is always intensive.  Murphy's Law of "Nothing is as easy as it looks" always seems to apply.  Well done, as usual!
@perrone1 Thanks Tony, like surgery.... one SLIP of the hand would've spelled disaster.  😲
Posted by: @marty-johnson
A true statement, period.  And 99.8% of the time that has certainly the been MY experience!
In this case, however, I theorized, more-or-less, EXACTLY what I discovered once the model was apart.  The BONUS was that the gray headliner was NOT glued in (as I theorized ) but instead held down by 4 rivets that I simply cut around then inserted dental floss to exert upward pressure from underneath.    Happily, it worked perfectly.  😀
Posted by: @chris
Posted by: @chris
A surgeon in a past life Chris? Amazing work, thanks for sharing the details and pics.
