How to make a flat ...
[Closed] How to make a flat tire....some help needed.........
4 Users
Richard Dube
(@nickies)
I want to have a flat spare tire for my DM 57 Belair. Anybody can give me some information how to modify an additional spare I have without blowing out the molded treads of the tire?
I have an industrial heat gun with many end tips. Is it the way to go? Slowly to soften the rubber and compress it?
Any help would be appreciated.
(@ronald-w-jones)
Reputable Member
Richard, you can check with.............
Charles or Paul Land at http://www.rustrus.com they do the most realistic flat tires I have ever seen for there award winning diaramas. I am sure they could give you expert advice or even do it for you. the email adress is clandr@mindspring.com you can check out their website and check out their photo gallerys of their cars and diaramas.
Rick Scoville
(@topgun1954)
Richard, the tires that come on the DM Bel Air are molded rubber, most likely a synthetic (SBR, Isoprene, etc). These compounds are usually highly extended with fillers to keep the cost down. Unfortunately, once the tire has been molded and "cured", the polymer chain has been set or linked and can't be reversed. Oh, you could pour high heat to the tire, but all it would do is begin to smolder and burn. Could get ugly.
If the tires were a true vinyl (PVC, PA, etc.), you maybe could heat them up to soften the vinyl, but chances are the treads (and entire tire) would just distort.
Your best bet is going with the previous post and seeing if there is an aftermarket company that would do a flat for you.
For what it's worth.
(@Robert Mason)
How about rolling the car over a scail nail????
(@Robert Mason)
How about rolling the car over a scale nail????
