Be careful using Enamel Paint,some issues to consider-
I go way back with Krylon paints.I painted an entire 62 Ford P/U Truck using Krylon spray cans in the early 70,s.It looked pretty good although Earl Scheib would have probably been a lot cheaper.The problems using enamel on models is that it can take weeks for the paint to harden up,even though it feels like its hardened doesn't mean that it is.Enamel finishes can get finger prints or markings from wrapping them up in various types of tissue with tight pressure on the model.I have repaired countless models with wrinkled paint as a result of using enamels.I use Lacquers with a two part clear system that has a hardener in it.I have even used water base flat paint with a two part clear systems.This is just my two cents after years of making mistakes.
Agree. Enamels can stay soft and be easily damaged for quite a while..
I think people also think they can get away with just applying a couple of coats of enamel colour to bare metal or plastic, and the result is easily chipped with a slight knock even after it seems properly hardened.
If you don't want to get into the complication of using a spraygun, the best results (certainly on white metal) are probably achieved with acrylic-based car spray paints using the recommended primer - or maybe even an etching primer, which "bites" into the metal surface and provides a solid key for the colour coat.
That still doesn't guarantee that you won't ever chip or damage the resulting finish, but it's a better bet.
A point to note: car sprays used to be cellulose-based, then switched to acrylic a few years ago (I think for environmental reasons). If you have some old cellulose primer and use it with a new acrylic colour - or vice versa - you may get an unfortunate reaction between the two. Best to buy primer and colour of the same brand and formulation.
I have tended to use enamel paints only for small added detailing, which has the added advantage that if you mess up the detailing you can quickly wipe it off with enamel thinner or white spirit (mineral spirits) without damaging the main acrylic paint coat, then have another try. If the main colour and the added detail are both enamel, you would remove part of the main coat along with the defective detailing, and have to repaint the whole lot.
Graeme.M. Ogg
London U.K.
More on paints
Like Gregory, I am a big fan, and user, of Krylon paints. My stock pile of them over the last 25 years would cause the EPA cause for concern. When there is no longer propellant enough to spray them, too frugal to invest in an airbrush,I have learned how to extract the paint and use it in a Prevo Sprayer. Krylon colors can be polished with something like Blue Magic as the quality of the gloss can sometimes be inconsistent. To work around that I have recently (belatedly) discovered Testors Model Master High Gloss Clear Coat which will put an exceptional, virtually production model gloss, to a paint job. Since I believe this to be an enamel material one has to force oneself to put the model aside for at least a week before further assembly work as it takes about that long to be completely dry but the end result is worth it. I concur with my friend Graeme on the use of automotive touch up aerosol paints if one is looking for a very specific color. Some however will have metallics that look a bit too course. You will have to experiment a bit.
John F. Quilter
Eugene, Oregon USA
This is very good advice and I was only holding back before I asked some questions but a few have been covered here. I recently moved about 1000 miles from 25 years in one abode in Ill., all the way to Daniel Boone country here in Tenn. Therefore I had to dispose of all of my old spray paints. Now, picking up the hobby, some of the newer chemistry does not offer the ease of application nor the nice gloss of finish. So I am all ears here.
This is all very helpful stuff, gentlemen.
While I am pleased with the Krylon finish I have noticed that it may take a while to completely cure and harden. I appreciate the information provided by you all.
David Knight
Richmond, Virginia. USA
Spray can enamels are always soft and it is that reason that I don't use them. I use automotive enamels with hardener or automotive acrylic lacquer. I use an air brush and have some basic paints and a few toners to get the colors I need. Sometimes I order automotive acrylic lacquer from Model Car World. You can get most American car colors from them. They use the Ditzler/PPG color chips to mix their paint. Yes this is more expensive but worth it for me as the last thing I want is to take a chance on paint job after I have invested countless hours on one of my woodie conversions.
