(1941 Chevy) Anothe...
(1941 Chevy) Another 1/18 "trunk project:"
7 Users
72 Reactions
I have "more than one"  Eagle (Universal Hobbies) 1941 Chevrolets, and a few Wellys too, but..... all of them have their own idiosyncrasy factor - if you know what I mean. 😏
Perhaps I can make ONE good one; combining the best parts from each. The Eagle coupe is the better replica; therefore, I'll enhance that one.
First & foremost, however, that sealed trunk will need to be cut out & hinged properly (not like the Welly "dog-legs" ). So, that's where I started.
My next step will involve fabrication of both the L&R vertical slide struts (SEE PIC ).
Stay tuned......
Chevy 41 8
Chevy 41 7
Chevy 41 1
Chevy 41 2
Chevy 41 4
Chebvy 41 9
Chevy 41 10
Chevy 41 11
Chevy 41 13
Chevy 41 12
Chevy 41 14
Chevy 41 3
Chebvy 41 20
Chevy 41 15
Chevy 41 17
Chevy 41 16
Chevy 41 18
Chevy 41 19
Chevy 41 21
Chevy 41 22
Chevy 41 24
Chevy 41 23
Chevy 41 25
Posted by: @chris
remarkable! Great work Chris
Steve Jacobs, GDH, Christopher Moroni and 1 people reacted
This has taken quite some craftsmanship Chris. Holy Mackerel!! The steady hand - I can no longer imagine! Love to see your progress along the way sir!!
@geoff-jowett Thanks, I appreciate it.  😉
Posted by: @perrone1
"This has taken quite some craftsmanship....."
Thank you, but Tony, I swear on my Mother's eyes.....
....the hinge cuts & assembly were kind of a rush job - I was finishing up the grinding & gluing while I was on the phone; I wasn't giving the process my FULL attention.....   as evidenced by that RIGHT pivot plate  being  angled downward, not parallel as it should be like the LEFT.
It doesn't affect the "opening operation"  but I will fix it!
Next time, I'll get off the phone!  😉 😀
Chevy 41 26
Steve Jacobs, David Green, GDH and 1 people reacted
@chris
For you, luckily, it looks like an easy fix. I still marvel at the ingenuity to come up with all of that!
@perrone1 Thank you!    Yes, I took care of this hours ago - honest!     Perhaps a bit difficult to see, but they're now lined up perfectly.  😉     Now I can sleep at night........  😉 😉 😉
Chevy 41 27
Chevy 41 28
Chevy 41 29
GDH, Steve Jacobs, David Green and 1 people reacted
@chris Lined up and ready to rock. Color me super impressed - again!!  Cool
Very impressive workmanship.
@gdh Thank you sir!    😉
(@whodeytink)
You must have amazing small motor skills, Chris.  No way I could do any of that.
@whodeytink    Earlier today, I was grinding down all the edges to somewhat of a scale thickness BEFORE all the edging strips gets applied - one wrong move would've spelled disaster.   😉
- Perhaps I should be cutting diamonds instead?    🤔 🤨 😉
- Thanks for the compliments.  👍
Chevy 41 31
Chevy 41 30
Chevy 41 33
Chevy 41 34
Steve Jacobs and GDH reacted
 PART 3:
- The real work begins - shaping all the body trunk edges & channels after sanding down ALL the edges (trunk panel & body ) to a some-what scale thickness.
- The left side of the trunk opening needed to be shimmed up, once a bit of putty & paint are applied it will be invisible.    (...like the right side-shim on my '58 red Pontiac project - SEE PIC )
- Keen eyes will notice a tiny white, micro, side-shim on the left trunk pivot-point arm.
- Keen eyes will also notice a bit of a "wobbly gap"  between the bottom edge of the trunk and the body.    That had to be filled with another micro-thin  shim.    😉
PART 4 will deal with fabrication of the trunk panel underside.    Stay tuned.........    🤓 🧐 🤓
Chevy 41 31
Chevy 41 30
Chevy 41 33
Chevy 41 34
Chevy 41 45
Chevy 41 46
Chevy 41 42
Chevy 41 47
Chevy 41 40
Chevy 41 39
Chevy 41 37
Pon 95
Pon 93
Chevy 41 43
Chevy 41 44
Chevy 41 35
This post was modified 1 month ago by Christopher Moroni
Amazing skill and patience once again Chris!
Chris the last underside pic shows what looks to be a genuine 1:1 part ready for restoration. Nice to see a couple of shots of the Pontiac.
