1958 Lincoln Contin...
1958 Lincoln Continental arrived banana shaped, help
12 Users
44 Reactions
(@john-quilter)
Got this NEO Lincoln today on a deep discount, well you get what you pay for, it's pretty droopy at the rear.   Pondering what, if anything,  I can do to improve it.  It appears the body was simply cast incorrectly, not something that happened over time while the resin cured as the rocker panel is straight but the trunk lid definitely slopes down about 1/8th inch at the top of the fin.  So even if it was possible to somehow heat it and straighten it that would not correct the issue.  My next thought is to use a razor saw at the rear door joint and cut out a  small wedge and glue back together to eliminate at least some of the droop.  I do have it apart and this looks possible.  So I ask the brain trust here,  any suggestions?
1958 Lincoln #1
1958 Lincoln #2
John F. Quilter
Eugene, Oregon USA
Sorry John but from what I've ever heard it will break or shatter easily if you mess with it.
Neo should be ashamed of themselves trying to market stuff like this.  They have to know perfectly well these models are flawed beyond salvation but they try to flog them anyways.  I have bought a few bananas from Europe where it costs more to return it.  I never deal with these vendors again after such an experience.  Goldvargs are made in China too and look at the quality control difference.  Sergio takes pride in his product and has strong ethics...others simply don't.
cadillaclloyd
(@lloyd-mecca)
Noble Member
Usually, when our resident Cadillac specialists indicate a models is banana shape, many chime in and say it is the photo. Don't hear that now...where is everyone?
That Lincoln was banana shape from the first photo weeks ago. What usually happens when the company finds these banana shapes, they don't accept them and they don't get in the marketplace. It is true, Sergio is on the lookout for that. Others do not care.
John Merritt
(@jcarnutz)
That is a shame, unfortunately I recently added one to my collection as well. Mine is also badly shaped. Too bad too, as it a great color.
John Merritt
South Lyon, Michigan - USA
Tony Perrone, cadillaclloyd, Tony Perrone and 1 people reacted
cadillaclloyd
(@lloyd-mecca)
Noble Member
Looking on eBay, I see one from the Netherlands that clearly has no bend. It looks better than all the rest. Of course, you need to be the judge.
(@moe-parr)
Here's my recently acquired 🍌 but it still looks great on the display shelf
20210221 174725
Barry Levittan
Long Island, NY
David H
(@d-m-holcombe)
Trusted Member
Thank you, John & John, for sharing your disappointing NEO purchases.  I shall be more wary when considering that brand. Serious David H
(@Anonymous 197205242)
Posted by: @lloyd-mecca
Umm, no, you weren't getting the idea. The I think point being made by people with some photo experience is be cautious and DON'T necessarily rely on photos to make definitive (usually negative) judgements. Here, John Quilter actually has the model in hand and can judge the problem _directly_ with observation. If a replica is unacceptable, consider sending it back for a correct one or a refund.
Here is another (actually largely the same) photo that John posted. But, it's not accurate to his model, is it ? Most of the time it is negative definitive judgements that are the issue ..... but the other way can happen, too.
Actually seeing the model in hand is the best way, and _good_ photographs of a typical production replica can help.
Lincoln 1a
Harv Goranson
(@mg-harv)
When I was a kid and I now longer liked a model I built, I blew it up with firecrackers! My only suggestion to you John.
David H
(@d-m-holcombe)
Trusted Member
IMG 8267
IMG 8263
Just a suggestion. . . Beg   (Click on picture for enlargement.)
(@stanton-lyman)
Estimable Member
John,  I own an earlier edition of this model, (Black), and it does not appear prone to the dread "Neo" 'banana' syndrome.
My '57 Mercury TP Cruiser convertible and the '59 Olds '98 convertible both are 'banana' shaped. Really sad.
I would suggest seeking an earlier black version, which in my opinion is a pretty good model, when straight.
(@john-quilter)
@stanton-lyman  The model is in the "body shop" for repairs as I write.  Stay tuned, it looks like it will get fixed.
John F. Quilter
Eugene, Oregon USA
John Kuvakas
(@jkuvakas)
Illustrious Member Admin
I'm no expert on this issue. But, I heard that the banana shape may be due to removing the model from the molds a bit too soon. That would explain why some batches seem to have the malady and others don't.
John Kuvakas
Warrenton, VA
Posted by: @jkuvakas
I agree this is a likely possible explanation, John, given the mix of ones that are bad and those that are OK.
@mg-harv  Hahaha....Harv;  I did the firecracker auto wrecking as well !!
