1958 Pontiac projec...
1958 Pontiac project.... "Marlowe-ish!"
9 Users
196 Reactions
The LAST thing I need is ANOTHER 1/18 project, but here we are.  Remember when Marty combined TWO 1/18 Mopars  to make ONE?    Well...  now it's my turn.
The idea of "kit-bashing"  an Ertl 1/18 1958 Chevrolet Impala with a Yat-ming 1/18 1958 Pontiac Bonneville has been with me for decades....  I can't promise I'll even finish this project, but here's my progress thus far.
- Of course, I had to cut the trunk out - I mean - why do ALL this work just to end up with a "sealed trunk?"    That would be unacceptable!
MARTY'S PROJECT FROM YEARS AGO:
M Y 5
M Y 8
M Y 13
MY GOAL:
Pon 14
Pon 13
MY PROGRESS THUS FAR:
Pon 15
Pon 11
Pon 9
Pon 8
Pon 12
Pon 2
Pon 1
Pon 3
Pon 4
Pon 7
Pon 10
Pon 6
As always, stay tuned......  😉
Steve Jacobs, Rich Sufficool, Geno and 6 people reacted
PART 2:
Pon 25
Pon 26
Pon 19
Pon 20
Pon 18
Pon 22
Pon 16
Pon 17
Pon 23
Pon 24
Pon 21
Steve Jacobs, Geno, Marty Johnson and 6 people reacted
(@ed-davis)
Interesting project. Progress looks good. What did you use to cut out the trunk?
Ed Davis
Inverness, Illinois, USA
Posted by: @ed-davis
My trusty $6.99 Jeweler's saw - that's about the 12th 1/18 trunk I've cut out.   😀 😏
Parklane trunk 1
Parklane 2
Parklane trunk 15
Steve Jacobs, Geno, Greg and 3 people reacted
@chris   This isn't helping my envy problem.  Nice work!
Geno, Jack Dodds, Mark Sweeney and 1 people reacted
@gdh  Thanks!   (I'm always doing something... )      Perhaps you might enjoy this project, from a few years ago: 1/18 1956 Ford COE car hauler project…. – Forum 18 – The Diecast Zone Forums
NOTE: There's 11 pages to it, so....um...   beware!   😳 😳    Or, I suppose, you could just skip to the end, Page 11.   😀 😀
This post was modified 10 months ago by Christopher Moroni
Geno, Jack Dodds and GDH reacted
amazing work Chris, can I ask how do u plan to fill in the gap at the rear of the hardtop, this one:?
226987 Pon 19
This post was modified 10 months ago by Geoff Jowett
Geno, GDH, Christopher Moroni and 1 people reacted
Posted by: @geoff-jowett
"How do you plan to fill in the gap at the rear of the hardtop on this one?"
Honestly, that's the least of my worries.   I'll fill ANY gaps in ANY areas like I've always done:  "Any way possible."
That is, "large gaps"  will be filled in with scrap plastic sanded & shaped to fit then anchored down with glue.   Any smaller gaps will be filled with Bondo-body filler, followed by spot putty.   The area(s ) will then be sanded smooth, filled again with spot putty, then sanded again, etc...    until every surface is just right.
Like all bodywork; it's labor intensive but relatively E-Z peazy  stuff.    Any one of my numerous, but more involved, posted project tutorials has documented this routine.  😉
Steve Jacobs, Geno, Jack Dodds and 3 people reacted
@chris   Taking shortcuts leaves one with fewer experiences.  I'll do the full eleven pages for the fun of it.
Geno, Marty Johnson, Geoff Jowett and 1 people reacted
Marty Johnson
(@marty-johnson)
Your project is coming along quite nicely.  The photo I've attached shows that the proper shape has been achieved.  All that's required now is the finishing stuff.
I couldn't help but notice that you cut and removed the entire cowl section.  It differs from my approach, which was to cut at the base of the "A" pillars.  I recall being concerned that without that bracing provided by the cowl, body warping could be a problem.  I'm sure you considered it as well and didn't view it as a potential problem or took precautions to minimize that possibility.
GDH, Steve Jacobs, Geno and 2 people reacted
@marty-johnson Correct, "stability"  was a concern, but it was decided that the best course of action was to section as I did.   PART 3 will show all my attachments points in greater detail.
GDH, Geno, Jack Dodds and 1 people reacted
PART 3:
Pretty self-explanatory - filling in body voids & gaps by any means possible.     Appearance is of no concern because body-filler & primer will eventually smooth everything out.  It does appear, however, that I'll need to extend the deck lid closer to the rear window, then reshape the opening to include two slight curves.
Saty tuned, right?  🙄 🙄
Pon 32
Pon 27
Pon 29
Pon 28
Pon 30
Pon 31
Pon 36
Pon 37
Pon 33
Pon 34
Pon 35
Pon 38
GDH, Steve Jacobs, Geno and 3 people reacted
Marty Johnson
(@marty-johnson)
For me, there is something visually appealing when, at this early stage, the pieces are combined together, and the vision that was just a vision is now a reality.
GDH, Geno, Greg and 2 people reacted
PART 4:
Basically, PART 4 wraps up all the "bulky work."
Unfortunately, I had to cut the cowl section free to reposition it upward.  My initial clamping (while the epoxy dried ) had inadvertently smashed  that area too far down.  Also, I had to remove the R door hinge and reposition that to achieve the proper alignment - tedious work, but it had to be done.
All the big pieces are now in place & hinged including the elongated trunk.   '58 convertible trunks are shorter than '58 Bonneville hardtops, therefore the opening had to be made larger - going toward the rear window.
I then grafted a re-shaped section of the Impala trunk onto the Bonneville's to fill the void.   A machined lap-joint (stronger than a butt-joint ) was incorporated for strength.  The final step will involve scuffing the underside to facilitate a strong bond once a layer of epoxy putty is laid down - like a blanket.
PART 5 will start the body work - filling in ALL the gaps & seems with thin strip plastic, Bondo  and/or Tamiya putty.    Stay tuned......
Pon 44
PON 39
Pon 41
Pon 42
Pon 43
Pon 45
Pon 46
Pon 47
Pon 48
Pon 49
Pon 54
Pon 52
Pon 56
Pon 50
Pon 55
Pon 51
Pon 57
Pon 63
Pon 58
Pon 59
Pon 60
Pon 61
Pon 62
Pon 65
Pon 64
Pon 66
GDH, Steve Jacobs, Geno and 1 people reacted
Marty Johnson
(@marty-johnson)
This is coming together really nicely.  Once again, you're slavishly adhering to getting it "right!"
GDH, Geno, Tony Perrone and 2 people reacted
Page 1 / 4
